Dreambox LINUX komento syntaksit
Eli kaikille komentotilaa (esim.telnetin avulla) käyttäville. Ei kun linkkiä seuraten ja sitten kannattaa talentaa koko pitkä sivu joko omalle mikrolle tai paperille.
http://www.busybox.net/downloads/BusyBox.html
sisältää kaikkien seuraavien komentojen syntaksit optioineen
COMMANDS
Currently defined functions include:
addgroup, adduser, adjtimex, ar, arping, ash, awk, basename, bunzip2,
busybox, bzcat, cal, cat, chgrp, chmod, chown, chroot, chvt, clear, cmp,
cp, cpio, crond, crontab, cut, date, dc, dd, deallocvt, delgroup, deluser,
devfsd, df, dirname, dmesg, dos2unix, dpkg, dpkg-deb, du, dumpkmap,
dumpleases, echo, egrep, env, expr, false, fbset, fdflush, fdformat, fdisk,
fgrep, find, fold, free, freeramdisk, fsck.minix, ftpget, ftpput, getopt,
getty, grep, gunzip, gzip, halt, hdparm, head, hexdump, hostid, hostname,
httpd, hush, hwclock, id, ifconfig, ifdown, ifup, inetd, init, insmod,
install, ip, ipaddr, ipcalc, iplink, iproute, iptunnel, kill, killall,
klogd, lash, last, length, linuxrc, ln, loadfont, loadkmap, logger, login,
logname, logread, losetup, ls, lsmod, makedevs, md5sum, mesg, mkdir,
mkfifo, mkfs.minix, mknod, mkswap, mktemp, modprobe, more, mount, msh, mt,
mv, nameif, nc, netstat, nslookup, od, openvt, passwd, patch, pidof, ping,
ping6, pipe_progress, pivot_root, poweroff, printf, ps, pwd, rdate,
readlink, realpath, reboot, renice, reset, rm, rmdir, rmmod, route, rpm,
rpm2cpio, run-parts, rx, sed, seq, setkeycodes, sha1sum, sleep, sort,
start-stop-daemon, strings, stty, su, sulogin, swapoff, swapon, sync,
sysctl, syslogd, tail, tar, tee, telnet, telnetd, test, tftp, time, top,
touch, tr, traceroute, true, tty, udhcpc, udhcpd, umount, uname,
uncompress, uniq, unix2dos, unzip, uptime, usleep, uudecode, uuencode,
vconfig, vi, vlock, watch, watchdog, wc, wget, which, who, whoami, xargs,
yes, zcat
  • BusyBox - The Swiss Army Knife of Embedded Linux.pdf
    276.6 KB · Lukukerrat: 414
