DreamBox DM 600
DreamBox DM 600
Tulee myyntiin ilmeisesti 1.3.2007. Hinta Saksassa 289€.
- 250 MHz PowerPC Processor (350 Mips)
- Linux Operating System
- 1 x Smartcard-Reader
- MPEG2 Hardware decoding
- Common available NIMs (DVB-S, DVB-C, DVB-T)
- Tuner modules, Plug&Play
- V.24/RS232 Interface
- 10/100Mbit compatible Ethernet Interface
- 2 LED status
- 32 MByte Flash, 96 MByte Ram total
- integrated IDE UDMA66 Interface
- Support for internal HDD 2,5" in any capacity
- unlimited channel lists for TV/Radio
- channel-change time < 1 second
- full automatic service scan
- supports directly bouquet-lists
- supports EPG (electronic program guide)
- supports own videotext
- supports multiple LNB-Switching control (DiSEqC)
- fully adaptable OSD in many languages and skin-support
- S/PDIF Interface for digital bit stream out (AC-3)
- 1 x Scart-interfaces
- S-Video connector
- analoge modem
DreamBox DM600 technical data
DBS-Tuner:
Frequency Range 950 …. 2150 MHz
Signal Level - 65 dBm …. - 25 dBm
Signal-to-Noise Level 12 dB max.
DBS-Tuner Input Connector F-Type female
Input Impedance 75 Ohm
AFC +/- 3 MHz
Demodulation Shaped QPSK
FEC Viterbi and Reed-Solomon
Viterbirate 1/2, 2/3, 3/4, 5/6, 7/8, automatic assimilation
Roll-off Factor 35 %
Demultiplexing according ISO 13818-1
Video decoder:
Video Compression MPEG-2 and MPEG-1 compatible
Video Standard PAL G/ 25 Hz
Video Formats 4:3 / 16:9
Footage 16:9, automatic assimilation for 16:9 TV-Device (over Scart)
Letterbox precolating for 4:3 TV-Device
Audio decoder:
Audiokompression MPEG-1 & MPEG-2 Layer I and II
Audio Mode Dual (main/sub), Stereo
Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Output analog:
Output Level L/R 0,5 Vss on 600 Ohm
THD > 60 dB (1 kHz)
Crosstalk < -65 dB
Output digital:
Output Level 0,5 Vss on 75 Ohm
Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
S/PDIF-Output optical (AC3)
Video parameter:
Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
Teletext filter in conformity with ETS 300 472 Standard
TV-Scart:
Output: FBAS,RGB,S-Video
Serielle Interface RS 232:
Typ RS232 bidirectional
Bitrate 115,2 kBit/s max.
Plug Connector SUB-D-9
Function: Update of Firmware
Ethernet:
10/100 MBit compatible interface
Function: Update of Firmware, Connect to PC
UDMA66 IDE Interface:
Intern for connect 2,5" HDD
LNB Power and polarisation:
LNB Current 500mA max. ; short-circuit-proof
LNB Voltage vertical < 14V without load, > 11,5V at 400mA
LNB Voltage horizontal < 20V without load, > 17,3V at 400mA
LNB shut-off at Standby-Mode
Count of active satellite position:
DiSEqC 1.0/1.2 SAT POSITION / SAT OPTION
DiSEqC - Rotor Control
Power consumption:
< 15W / 12V
Input voltage:
DC12V,alternating acurrent +/- 15%
Extern power supply:
Input: 110-240V AC / 50-60Hz / 0,6A
Output: 12V = / 2,5A
Physical specification:
Ambient Temperature +15°C...+35°C
Humidity < 80%
Size (W x D x H): 195 mm x 130 mm x 40 mm
Weight: 0,6 kg
http://www.dream-multimedia-tv.de/english/products_dm600.php
    13.4 KB · Lukukerrat: 1,441
mphumax
Tampere
Octagon sf4008 s2x
Triax TD-110 +moteck sg-2100A
Octagon sx88
DrHD F15
Mystique SaTiX-S2 Sky V2 USB
