Debug Mode ongelmia
nameone
Espoo
Debug Mode ongelmia
En saa debug-modea päälle.
Nokia 2*AMD
Yritetty kahdella metodilla
1). METODI
Flash reset+pccboot, kahdella eri pccboot filellä:
icache is on
setenv product? 0
go 10000100
Branching to 0x1000010
->jumissa
2). METODI
minflsh:lla
> arun initactor -v -V -i 4
C_INIT: afexec of initactor failed - No such file or directory
started aid = 10
INIT Version 0.9 loaded
INIT: library path: "LD_LIBRARY_PATH=/root/platform/nokia-dbox2/lib:/root/platform/lib:/root/lib:/usr/lib"
INIT: start run level 2
INIT: execute "ddf"
INIT: time: 296 sec, 530000000 nsec
INIT: started aid = 11
INIT: execute "upgrade"
INIT: time: 300 sec, 450000000 nsec
INIT: start run level 4
INIT: execute "setenv SIEGEHOME /usr/siege"
INIT: execute "setenv CLASSPATH /usr/siege/lib/siege.jar:/usr/siege/lib/junior.jar:."
INIT: execute "siegep junior.finder.StartUp"
INIT: time: 325 sec, 390000000 nsec
INIT: afexec of siegep failed - No such file or directory
COM:
DebugEnabler (c) tmbinc, gillem +(sagem,amd,philips) 1.6finalR2
bl-version : 1.0
product? at : 10000944
current state : locked
flashrom type : 2x16 bit? yes. vendor: AMD
engaging gillem-code... test yoursel f by rebooting now ;)
Please reset now!
"You have to shorten the jumper XH3 (at the front next to the card reader)
Just connect he contacts if there are no jumper pins.
Connect the contacts firmly for as long as the write protection has to be disabled.
Shortly tipping them is not enough!
If there is output in the com-terminal like:
COULDN'T WRITE, IT'S STLL FFFFFFFF
then please sheck if there really are 9V at XH3.
Unfortunately, some boxes differ from this."
Tässä boxissa:
nastoissa +2,63 ja +3,19V ei 9V, voisiko se johtua siitä?
En oikein ymmärrä sitä ohjettakaan, miksi se write-protection jumpperi pitää ottaa pois puolivälissä?
Entä mikä on: Bootmanager das Script enable_debug_mit_minflsh.txt, ei minflsh mukana tullut tuollaista?
Sitten toi tuner.so ei ole uusin (1.6) , uusin on 1.8 beta, mutta sitä sivua ei ole enään, enkä löydä sitä mistään muualtakaan.
