wafer
- Porvoo
- *Octagon sf8008m
*Edision OS Mega
*TBS-5925
*Laminas OFC-1200 P + Inverto Black Ultra Quad
*Moteck SG-2100A / 30w - 46E
*** PORVOO***
DBF v3.141592 "Pi" Dreambox Image
Copy/Paste from Sat-Industry
So finally here it is.
Welcome to DBF v3.141592 "Pi" Dreambox Image based on:
+ kernel v. 2.6.9 (1.09)
+ enigma v. 1.0.9 DBFmod (28.03.2005)
+ driver v. 1.0.9
+ busybox 1.0 (17.03.2005)
+ Plugins:
+ CIFS
+ DBF Emu Manager
+ DBF EmuD Pro
+ Scriptservice 2.06
+ DreamCrypt
+ AutoDownloader
+ Advanced Management
+ Config Plugins ;-)
+ DBF BackgroundSelector
+ DreamNetCast build-in
+ Dvbsnoop
+ DBF Extras Menu
+ Internet Addon Installer
+ Manual Addon Installer
+ Remove Installed Addons
+ Var, CF Setup
+ Move Addons on USB / HDD
+ Infobar Settings
+ Advanced Deamon Settings
+ External Address Setup
+ NFS Server Setup
+ DBF User Menu
+ EMU Manager
+ Stream Manager
+ Plugins Manager
+ File manager
+ Process Manager
+ LAN Monitor Manager
+ Active EMU & Cryptinfos & SNR/AGC in Skin
Addons downloadable over Inet.
for special functions check the Docu
This Image is without Keys and without any EMU
We are not responsible for what you do with it.
Only with original DreamCrypt Support
Read the changelog to be aware of all changes and new Functions.
Based on Original DMM 109
with Enigma CVS 28-03-2005
Special thanks goes to: zg0re, ruDream, rel_cvss, Tom0000, PLi®
xphile, The Hydra Team, lololuy, hyrican
DBNA Team and dreamboxusa.com
and to all Emu and Image Developers out there. Greetz
Build & Compiled by the DBF IMAGE Team
If you want to get in touch with us you can go here:
h**p://image-team.cjb.net
CHANGELOG better late as never ;-)
28.03.2005
-Fix final Bug in Emu Manager
-Fix Bug in Settings Installer
27.03.2005
-Fix Bug in DBFemuD
-Fix Bug in DBF Emu Manager
-Add again new Libcrypto
26.03.2005
-CVS Update to Enigma 26.03.2005
-EasterEgg should work now *ggg*
25.03.2005
-Modified downloadable Skins to fit new Enigma Structure
if you want to add other Skin you should have these Entries in it:
<img name="mainmenu.dbf_usermenu" src="mainmenu/usermenu-fs8.png" />
<img name="mainmenu.dbf_usermenu.sel" src="mainmenu/usermenu_sel-fs8.png" />
<img name="mainmenu.dbf_extras" src="mainmenu/extras-fs8.png" />
<img name="mainmenu.dbf_extras.sel" src="mainmenu/extras_sel-fs8.png" />
- Added some more Fonts.
24.03.2005
-Added Lan Monitoring to DBF UserMenu
-Added NFS-User-Server
-Added NFS Server Setup to DBF_Extras/Advanced Settings
-Added enable/disable NFS Server to DBF_Extras/Advanced Settings (reboot to activate)
-Added enable/disable Corefile Debugging to DBF_Extras/Advanced Settings (reboot to activate)
-Added enable/disable Corefile CleanUp to DBF_Extras/Advanced Settings (reboot to activate)
-Final NTSC Skin Fixes
-Added SimpleSpace Big Skin
-Readded DreamCrypt EMU
23.03.2005
-CVS Update to Enigma 23.03.2005
-Added YPbPr to Colorformat in Enigma Setupwindow
-Added Setup External Addres to DBF_Extras/Advanced Settings
for setting external DreamIP to use with WebInterface - m3u Streaming
(if nothing set DreamIp gets used. else external adress will be used for Playlist)
uses /var/tuxbox/config/external_address for now.
-Added DBFemuD HTTP Auth Settings to DBF_Extras/Advanced Settings (reboot to activate)
this is predefined with root:dreambox
you have to edit this one if you want OSD from Emu Daemon and have changed Dreambox Password and HTTP Auth is enabled
Also you need to change the pass for your desired emu if its supported. Else: DONT touch this !
-Added HTTP Auth checking to DBFemuD
-Added HTTP Auth checking to external Installer
-Added Scriptservice 2.07
-Removed some unused Code
-Rewrite of some Code Parts
22.03.2005
-Final Fix in Dish Network EPG
-Fix some Positions for NTSC Skin
-Fix Bug in DBFemuD
-Fix Bug in external Addon Installer
20.03.2005
-Code CleanUp
-Fixed Bug in Enigma Settings Installer
-Added open DreamNetCast on long press of Audio Button, short opens Audio as usual
-Added open DBF USERMENU on press of Shift_Yellow Buttons
-Added open FileMode on long press of TEXT Button, short opens VideoText as usual
-Dreambox Keyboard should work similiar, no possibility to test.
17.03.2005
-Added easter Egg ;-)
-Fix valign for NTSC in Enigma and DBF Codebase
-Added NTSC Skins
-Fix Skin Bugs
-Fix some Buttons in Enigma Code
-Iptables Addon will follow
15.03.2005
-CDK Update to 109 final DMM
-Added DBF MVI Background Selector for Radio/Scan/Mp3 Background Picture
reachable over Settings/System/OSD Setup !
(scans for mvi in /share/tuxbox/enigma/pictures, /var/tuxbox/config/enigma/pictures & /hdd/pictures
- New Simple Space default Skin
- Added more USB Drivers & IPtables & Tunneling Driver to Kernel
14.03.2005
- new Libcrypto added
- fixes for DBF USERMENU
- Added addonset.so and audown.so for easier use in ScriptService
13.03.2005
-Added DishNetworks and BEV USA EPG Support (should work now)
-Added Enigma restart to Shutdown Menu
-Added new tags to Addon Installer (settings + ipkg + update)
-Added DreamNetCast to Enigma
11.03.2005
-Fixed DBFemuD small bugs
-Fixed Emu remember some bugs
-Added DBF USERMENU to enigma & skins - this brakes all other skins now !!!
08.03.2005
add ipkg & Settings support to external Installer (for later use in All in One)
Earlier Bugfixes as we remember them
-Fixed TEXT Button not changing Mode if no VTXT Available
-Fixed some Messageboxes
-Optimize DBFemuD Codebase
-Fixed Busybox Killall bug
-Added telnetd support to busybox with patch from busybox mailing list.
-New Move Var to HDD/USB Routines
Much Much More. i dunno remember ;-)
Greetz
Spacy
Ja tämä image löytyy ainakin Sat-Industrista jos ei muualta vielä löydy. Itse en ole kerennyt tätä uutukaista vielä kokeilemaan..
/Wafer
+ driver v. 1.0.9
+ Plugins:
+ CIFS
+ DBF Emu Manager
+ DBF EmuD Pro
+ DreamCrypt
+ AutoDownloader
+ Dvbsnoop
+ DBF Extras Menu
+ Var, CF Setup
+ Infobar Settings
+ NFS Server Setup
+ DBF User Menu
+ EMU Manager
+ Stream Manager
+ Plugins Manager
+ File manager
+ Process Manager
28.03.2005
27.03.2005
-Fix Bug in DBFemuD
26.03.2005
25.03.2005
24.03.2005
23.03.2005
22.03.2005
-Fix Bug in DBFemuD
20.03.2005
-Code CleanUp
17.03.2005
-Added NTSC Skins
-Fix Skin Bugs
15.03.2005
14.03.2005
13.03.2005
11.03.2005
08.03.2005
Greetz
Spacy
/Wafer
