DaVinci 5
The Satnews Dreambox Team
109.1d_SDT_DaVinci5.img
Image for FLASH / USB / HDD / NFS
- Kernel and Modules 2.6.9 - Release 1.09_1d
- Enigma 1.09 - CVS 11/08/2005, modified by SDT
- WebIf 4.6.3 Expert
- Tuxtxt v. 1.90
This Image, if installed in Flash, will upgrade your FrontProcessor to Vers. 1.06
NEWS DaVinci 5:
- Zapping Lite Skin
You can share two skins at the same time.
While zapping channels, a second skin will be displayed on OSD, generally a light skin, but maybe a second complete skin reorganized on the screen: lot of possibilities for skins developers.
Zapping Lite Skin can be disabled on SDT boss panel -> OSD setup.
- SDT Advanced Infos
Very powerful unique window, full of advanced infos, customized for each emu.
You can also define and run up to 9 scripts, with output on screen, stored into /var/SDT/scripts/customX.sh, where X is a number from 1 to 9
- Movie recording directory
Choose where to store your recordings, you can choose between three default positions and two user definable positions.
A test of the choosen device will be performed, displaying the amount of free space (GB) and free time (estimated, HH:MM) available for recording.
A comfortable shortcut to Enigma "Mounts" window makes easy to mount/umount the connected devices with just a few remote control clicks, then to select them as recording devices.
- Enhanced Smart_init:
More than settings, you can install DaVinci addons also with new smart_init procedure!
Check below on this document for instructions.
- SDT custom scripts:
Up to 9 scripts can be defined, and launched from Advanced Infos Window.
The output will be displayed on TV screen..
- Shortcuts
BLUE button:
1 click: SDT boss panel
2 single clicks: "Utilities" Window
3 single clicks: "Enigma Extra Setup" Window
YELLOW button:
double-click: "SDT Advanced Infos" Window
GREEN button:
double-click: "Timer List" Window!
- Plugins Window
Now is taller, showing 13 plugins without scrolling, instead of 8 (enigma standard).
- Save All Settings
Save image settings for smart_init procedure.
It is on SDT boss panel -> Enigma Extra Setup -> Save all settings.
Very useful for upgrading to a new DaVinci image, or reinstalling.
You'll find all current settings made for the current image automatically reloaded on the new one.
- SAMBA
Enable/Disable Samba is now available on Enigma Expert Setup ("enable file sharing").
You must reboot dreambox to activate changes.
- LCD logo
Nice LCD boot logo (by Hiii2)
- OSD
Provider shown on OSD (near Channel name)
MULTI AUDIO icon on OSD
TELETEXT icon on OSD
Frequency, Polarisation, SymbolRate, FEC of transponder on OSD
- SKIN
Default skin is now VisivaBox Extreme 2 skin,
modified for DaVinci image (by DDAAXX - VisivaGroup)
SDT unique features:
- SDT Advanced Infos, Very powerful and unique emu's advanced info center.
- Time Controlled Parental Control - define your protection-activation daily timetable
- EPG Wizard - download only the channels of your choice total automatically
- Flash erase via Remote Control
- FlashWizard Remote: FW program inside the box!
- Smart_Init: install flash or multiboot image with auto-setup!
- Usb stick also available from /usb (just like /hdd)
- The most complete OSD available at the moment.
- SDT shell boot window
Other Features:
- SDT Boss Panel (blue key), upgradable from internet
- Movie recording directory, choose recording device.
- Display SNR - AGC- BER on OSD
- Display Provider's name on OSD
- Display Multi-audio and Teletext on OSD
- Display stream infos on OSD
- Display channel encryption(s) on OSD
- Display current Emu on OSD
- Internet download of addons
- Manual install of addons from /tmp
- Addons manager, installer and uninstaller
- Place addons on USB or HDD
- Check /var place, and available free space
- SWAP file advanced setup from Boss Panel
- OSD timeout configurable from SDT menu
- HDD configuration (sleep and acoustic) from menu
- Skin Visivabox Extreme 2 - 4:3 and 16:9 versions
- Emuboss is now totally software configurable
- SAMBA is included
- Reiserfs is optional and dowlodable from Addons-Download
- CIFS is optional and dowlodable from Addons-Download
- Complete busybox (nc, netstat, renice, cut, and more.)
- Up to 9 scripts user-definable, output on TV screen.
- Auto-recognition of install place, flash or multiboot
- Automount disc/part1 usb stick
- Autoclean core files on hdd
- Added "restart enigma" (hot restart) on shutdown menu
- Tetris game included
- Recover Movies (in menu Enigma Extra Setup)
- SDT latest news download and display
- This firmware contains no emus and no keys -
All Other Addons Available From Direct Download!
QUICK HOW-TO:
A FlashWizard program inside the box, with full "SmartSettings copy" available.
You can install/remove images without windows program:
FTP one (or more) images into /usb or /hdd, then choose the install device, and
SmartSettings enable/disable.. done!
Useful option for all linux/macintosh friends, who like to use FlashWizard
outside Windows o.s.
- Smart_Init
You can install this image (even if on flash), and have it
full configured with your custom settings even at first boot.
How to do this:
1) Create a directory /usb/SDT/smart_init ( or /hdd/SDT/smart_init )
2) Then create 2 directories inside smart_init: "settings" and "addons"
3) Copy into "settings" directory your favourite settings (likra, pet, comax, etc.etc.)
(make sure to copy all the settings files, included satellites.xml)
Put just files there, do not put folders.
OR:
Use the menu "Save ALL settings" located in SDT Boss Panel -> Enigma Extra Setup
4) into the "addons" directory, you can put DaVinci's addons files (*.tar.gz): the image will install them automatically!
Warning:
if you are installing the image on flash, DO NOT put too much addons into!!
Free space on Flash is very little!!
5) Done.
DaVinci image will boot up and auto-configure itself with all your
settings: favourites, channel lists, language, network, video, etc.etc.
plus addons (if any).
On flash-erase, or new install, the image will check if smart_init folder
exists, and re-initialize itself automatically with your favourite set-up.
Very useful option for all rotor/multi-lnb users.
No more loooong setup from scratch at every install.
http://www.satnews.tv/images/109.1d_SDT_DaVinci5.zip
- Tuxtxt v. 1.90
NEWS DaVinci 5:
- Zapping Lite Skin
- Shortcuts
BLUE button:
YELLOW button:
GREEN button:
- Plugins Window
- Save All Settings
- SAMBA
- LCD logo
- OSD
- SKIN
Other Features:
- SAMBA is included
QUICK HOW-TO:
- Smart_Init
How to do this:
OR:
Warning:
5) Done.
