DaVinci 5.7: 7000
DaVinci 5.7: 7000
The Satnews Dreambox Team
SDT DaVinci 5.7 FINAL
- Kernel and modules 2.6.9 (1_09.1d)
- Enigma compiled 17/05/2006 - CVS modified by SDTeam
- WebIf 5.9.7-Expert-Enhanced (SDT)
- TuxTxt 1.98 (teletext)
- Movieplayer 0.8.1
- SDTboss Panel v2.7.0
- emuboss v2.9.5 (emumanager)
- Enhanced SDT Web Interface
You can access SDT custom web-if page and do emu start/restart, and read advanced infos.
To access: press "SDT Team" button on main web-if page.
Web-if itself is now full restyled and adapted by Mimi74
- Change emu from shell command:
You can now start/restart installed emus with "wget" command too, in example:
~ > wget http://root:dreambox@192.168.1.24/SD...on Interface
- 360 Kbytes more free space in flash /var !!
Some stuff has been moved to read only memory, freeing up useful space for those who don't use external memory devices
- Inadyn setup
Inadyn configure setup by DreamEasy is now provided in SDT Boss Panel's Extra Setup Window (3x blue button)
- Setup Lock extended to SDT Boss Panel and SDT Advanced Infos window
If you have locked the access to the setup window with a PIN code, then it will be asked for accessing Boss Panel and Advanced Infos too.
- included main italian FTA channels (TV-Radio) by default, if no settings are loaded
Organized into 2 default bouquets:
mode TV: "Canali italiani"
mode Radio: "Canali italiani (Radio)"
- URL for downloading addons must be specified by the user
DaVinci image is not provided by default with a download URL:
the user must enter it in "Install Addons" window, a "URL :" text input field is there.
The URL is saved in a file "/var/SDT/addons.url" that can be backupped and replaced
by the user when updating to a new DaVinci image version.
Smart_Init procedure will do the URL backup/restore as well.
- Smart_Init updated
added new files to be automatically backupped and restored:
panel.url, addons.url (defined urls)
epg.wiz (the user cannels list to download with EPG Wizard)
- Various updates and bugfixes
Recent Hystory:
DV 5.6:
- TeleText (Televideo) now available also from Web-Interface (new very useful new CVS feature)
Go to web-int, then press "TEXT" link on the top-right (near VLC button)
- TunerA icon on OSD:
Already available on 7025, but new on 7000:
icon lights when the service is tuned, stay black if tune has failed, or channel is not transmitting a signal.
- FlashWizard remote:
now is useable also from Multiboot installed images, allowing full operations.
No more need to use it only from flash image.
- all skins updates:
Anim5.6 new from Mimi74
Megalight 1.3a from Eagle
- full cleanup of OSD implementation:
now only the needed infos are displayed in each operating mode (TV, Radio, File)
- bugfixes and updates, as ever! :)
DV 5.5:
- Support for an alternate Remote Control (!! new !!):
On DaVinci 5.5 you can select the keymapping for "Philips Pronto" or another compatible programmable remote control.
This is an absolutely innovative option, never seen on any other image before!!
- ECM Display on OSD:
Yellow, if encrypion is present (emm)
Green, if it is used for decoding (ecm)
- Decoding source display on OSD (card / emu / network)
- Added Betacrypt to known encryptions icons, displayed on OSD for ecm and emm
- Camd3:
added caInfo as default item when SDT Advanced Infos window displays.
- Gbox:
added SC item on SDT Advanced Infos window, displays full infos on inserted sc.
- Skins:
Added latest Mimi "Anim 5.5" compact/extended 4:3/16:9, and Eagle's Megalight 1.2
- Locales:
Added updated Italian and French translations
- A/V Settings shortcut:
Added very useful shortcut to "Audio/Video Setup" window in BOSS Panel's "Extra Setup" (3x Blue Key)
- EPG Wizard:
updated default download channel to "SKY Assist"
- As ever:
various updates and fixes to emuboss and all the rest
!!! WARNING - IMPORTANT DISCLAIMER:
!!! THIS FIRMWARE DOES NOT INCLUDE KEYS, OR EMULATORS, OR URLS FOR DOWNLOADING ILLEGAL STUFFS OF ANY TYPE.
!!! SATNEWS DREAMBOX TEAM IS NOT RESPONSIBLE IN ANY WAY FOR WHAT THE USERS WILL DO WITH THIS FIRMWARE.
http://www.satnews.tv.it/ricevitori/dreambox/firmware/index.shtml
