DaVinci 5.3
News in DaVinci 5.3: =============== = =
- WONDERFUL WebInterface of Mimi74 introduced the WebInterface Enter and looked at that masterpiece!! THANKS MIMI74:
3 SKINS INTRODUCED: - Visivabox VB Extreme 2.0 4:3 - 16:9 - MegaLight 1.1 by Eagle - Mimi74 SDT_6 4:3 - 16:9
- Emuboss totally reviewed Added the possibility of to have a script for kill every emu. The script should have for name *.emu_kill and should find itself always in /var/SDT famous to the kill of the relevant emu. The script is optional,
if there is not not, so ALL of THE addons will be performed previous emu will be compatible with the 5.3
- When it enters to EpgWizard comes disabled the epg automatic cache Comes then risettata to the original state to the gone out This caused some problems of memory for the double discharge of the epg (EPGwizard + cache of enigma together) while is itself on. Now it is at place, it there is not problems of memory,
also without the swap-file activated
- movieplayer. xml moved in /var/tuxbox/config Now is editabile, even if the image is in flash
- fix the creation/active/removal of the swap file
- fix the mount CF in rcS
- varied updatings
Other features DaVinci:
- Zapping Lite Skin
Two skins can at the same time be had distinguished.
During zapping with the arrows of the remote control (the adjacent channels), it comes visualized a second skin, generally with minimal information (argument skin), but to chosen also complete like first and the organized one various to video, with full creative possibility for the sviluppatori of skins.
In order to return to the full skin enough to press OK, while if it is made zapping with the skin complete already visible, it comes maintained until expiring of its timeout (or OK is still not pressed).
The Zapping Lite Skin is disabilitabile from the SDT boss panel in OSD setup.
- SDT Advanced Infos
Very powerful unique window, full of advanced infos, customized for each emu.
You can also define and run up to 9 scripts, with output on screen, stored into /var/SDT/scripts/customX.sh, where X is a number from 1 to 9
- Movie recording directory
Choose where to store your recordings, you can choose between three default positions and two user definable positions.
A test of the choosen device will be performed, displaying the amount of free space (GB) and free time (estimated, HH:MM) available for recording.
A comfortable shortcut to Enigma "Mounts" window makes easy to mount/umount the connected devices with just a few remote control clicks, then to select them as recording devices.
- Enhanced Smart_init:
More than settings, you can install DaVinci addons also with new smart_init procedure!
Check below on this document for instructions.
- SDT custom scripts:
Up to 9 scripts can be defined, and launched from Advanced Infos Window.
The output will be displayed on TV screen..
- Shortcuts
BLUE button:
1 click: SDT boss panel
2 single clicks: "Utilities" Window
3 single clicks: "Enigma Extra Setup" Window
YELLOW button:
double-click: "SDT Advanced Infos" Window
GREEN button:
double-click: "Timer List" Window!
- Plugins Window
Now is taller, showing 13 plugins without scrolling, instead of 8 (enigma standard).
- Save All Settings
Save image settings for smart_init procedure.
It is on SDT boss panel -> Enigma Extra Setup -> Save all settings.
Very useful for upgrading to a new DaVinci image, or reinstalling.
You'll find all current settings made for the current image automatically reloaded on the new one
SDT unique features:
- SDT Advanced Infos, Very powerful and unique emu's advanced info center.
- Zapping Lite Skin, two skins at the same time, of which one simplified for the zapping
- Parentale Block to time - you define the every day timetable of activation of
protection.
- EPG Wizard - download only the channels of your choice total automatically
- Flash erase via Remote control
- FlashWizard Remote: FW program inside the box!
- Smart_Init: install flash or multiboot image with auto-setup!
- Usb stick also available from /usb (just like /hdd)
- The most complete OSD available at the moment.
- SDT shell boot window
Other Features:
- SDT Boss Panel (blue key), upgradable from internet
- Movie recording directory, choose recording device.
- Display SNR - AGC- BER on OSD
- Display Provider's name on OSD
- Display Multi-audio and Teletext on OSD
- Display stream infos on OSD
- Display channel encryption(s) on OSD
- Display current Emu on OSD
- Internet download of addons
- Manual install of addons from /tmp
- Addons manager, installer and uninstaller
- Place addons on USB or HDD
- Check /var place, and available free space
- SWAP file advanced setup from Boss Panel
- OSD timeout configurable from SDT menu
- HDD configuration (sleep and acoustic) from menu
- Skin Visivabox Extreme 2 - 4:3 and 16:9 versions
- Emuboss is now totally software configurable
- SAMBA is included
- Reiserfs is optional and dowlodable from Addons-Download
- CIFS is optional and dowlodable from Addons-Download
- Complete busybox (nc, netstat, renice, cut, and more.)
- Up to 9 scripts user-definable, output on TV screen.
- Auto-recognition of install place, flash or multiboot
- Automount disc/part1 usb stick
- Autoclean core files on hdd
- Added "restart enigma" (hot restart) on shutdown menu
- Tetris game included
- Recover Movies (in menu Enigma Extra Setup)
- SDT latest news download and display
- This firmware contains no emus and no *** interdis *** -
Täältä löytyy:
http://www.satnews.tv/images/109.1d_SDT_DaVinci5_3.zip
- varied updatings
- Zapping Lite Skin
- Shortcuts
BLUE button:
YELLOW button:
GREEN button:
- Plugins Window
- Save All Settings
protection.
Other Features:
- SAMBA is included
Täältä löytyy:
