Colosseum7000 1.1 image
COLOSSEUM TEAM IMAGES
powered by
EINSTEIN DREAMBOX GROUP (EDG)
COLOSSEUM 7000 1.1 IMAGE
Released 17.10.2006
Immagine per FLASH / USB / HDD / CF / NFS
- Kernel e Moduli 2.6.9 - Release 1.1.0
- Enigma 1.09 - CVS aggiornato al 17/10/2006, modificato da CTEAM
- squashfs 2.2-r2 con compressione LZMA
- busybox v1.01
- WebIf 5.9.7-Expert-Enhanced (CTEAM)
- Tuxtxt v. 1.98
Novità Colosseum 1.1:
===================- AUTOMATIC STANDBY
You can program the receiver to automatically go to standby after a complete reboot, or at a given
time, only if it is not recording.
Very useful in case of main power black-out: when power comes back, the dreambox will boot-up and
automatically set itself to standby.
- LCD Display dimmed when OSD is hidden
Another premiere for Enigma1:
Colosseum 1.1 allows to set a different brightness of LCD display when OSD is not visible on the
screen.
Many people do not like the full brightness of LCD at all time, by setting this option you can have the
LCD full light only when it has useful infos to be read.
- TIMED SCRIPTS
Setup and execute timed scripts directly from Colosseum CCC panel, with full advanced options (execute
only at the end of a recording, and repeat mode setup)
- user defined Enigma EPG cache directory location
You can save the Enigma EPG cache data on any available device: usb, cf or hdd.
- more infos available on OSD
Check them out yourself.... ;-)
- As ever, many fixes and image restyling
- Buttons
BLUE BUTTON:
1 click: Colosseum Control Center (CCC) panel
2 single clicks: "Utilities" panel
3 single clicks: "Enigma Extra Setup" panel
4 single clicks: "Advanced" panel
YELLOW BUTTON:
single click: plugins window
double click: opens "Colosseum Advanced Infos" window
GREEN BUTTON:
single click: channel's subservices menu
double click: shortcut to "Timer List" window
RED BUTTON:
single click: show EPG
double click: setup EPG viewing (single - multi - MV pugin - EPGUI plugin)
- Web-If
Colosseum image has a full personalized Web-If, skinned by Army.
Check out the power of custom implementations of the web-if, available thru the "Colosseum" button on
the top left of the main web-if window.
You can start-stop-restart both cardserver and/or emus, plus you can find out full infos on current
channel, and (world premiere) you can edit the emu and cardserver's config files directly on your web
browser's window!!!
No more to use a ftp program for editing config files.
- Time driven parental control
Colosseum image is the first and only image that allow to set up a time interval for activating and
deactivating the parental lock for locked channels.
You can set up the hours:minutes when parental lock become active, and the hours:minutes when it will
be deactivated.
The image will perform automatically everyday the locking and unlocking at given hours.
!!! WARNING - IMPORTANT DISCLAIMER:
!!! THIS FIRMWARE DOES NOT INCLUDE KEYS, NOR EMULATORS, NOR URLS FOR DOWNLOADING ILLEGAL STUFFS OF ANY TYPE.
!!! EDG IS NOT RESPONSIBLE IN ANY WAY FOR WHAT THE USERS WILL DO WITH THIS FIRMWARE.
