7020: Gemini Image 2.50
Gemini v2.50:
Technical Information:
* Enigma:20.11.2005
* GCC 3.4.4 Original CVS
* Web Interface: 5.7.0-Expert
* Busybox 1.01 ( <=7000 )
* Busybox 1.00 ( ==7020 )
Button Functions:
* 2x BLUE - BP -> Extras/SETTINGS
* YELLOW - Quick-Button (CAN BE ADJUSTED OVER BLUE PANEL)
* RED - EPG List FOR CURRENT CHANNEL
* 2x RED - EPG Style Menu
* GREEN - Subservices
* Own Addon-Server via Internet.
* AutoCam: Emus can be linked to Channel/Provider
* Cam-Settings: for example Renaming of Emus, Multichannel-Patch adjustable ( >=7000 )
* OSD: EMM- and ECM- Display adjustable
* Possibillity of download and automatical install of extra Functions via Internet from the Gemini -Server
* System Info: Many exrta infos about your Box (for example Harddisk-Temperature or all other Enigma-Settings)
* Gemini-News are loaded in the backround
* JPEGs can be turned and the EXIF-Tags can be displayed ( >=7000 )
* Support for OGG/Vorbis
* Random - Function for MP3 and OGG
* Quick-Button-Menu: Many extra Functions for the yellow button
* smbmount
* Support for CDROM/DVD, doesn't matter if IDE or USB ( >=7000 )
* Record CIFS/NFS: Record to a CIFS or NFS mounted Harddisk (only possible if no Harddisk is present in the box,the Mountpoint has to be "/mnt/usb" with a Minimum of 3GB)
* Extra Menu: Settings for many Extras like Inadyn, HTTPD, EPG-Cache, setting var to usb/hdd and many more
* Backup Function
* Dreamnetcast: with Shoutcast TOP(100)
* Backround pictures for Radio, MP3 and SCAN can be chosen over Blue Panel.
* Custom Scripts can be started over Blue Panel
* Calender including Reminder (can be changed over .../gemini_cal.conf)
* Possibillity to reroute Syslogd + Enigma-Debug-Messages to Syslog
* Menu to change the Password.
* Process-Info & Memory-Info in System-Informations
* BP has a new style
* Enigma-Settings in Sysinfo-Folder with Delete-Function
* MHW-EPG from CVS is activated
Interfaces WebIF:
http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = Nummer des Cams)
http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = Nummer des Cams)
We'd like to thank everybody who paricipated in the "Gemini sugestions" Thread.
Unfortunatly many things are,from our side, not possible to realize.
This Images doesn't contain any keys or Softcams.
and won't be supported!
Recommendation:
If you don't install the Image in the Flash of your box,
then the Flash image you use shouldn't be to old.
A swap file/partition (>= 16MB) should be present if you have several processes running in backround.
http://www.mpw.hu/dbw/dm7020/images/Gemini250_7020.zip
Thanks alot and have Fun
