2sub & 2lang for Dm7025
crashi
World Premiere!.
2SUB & 2LANG
This archive contains two plugins/addons for Dreambox 7025 written by Gruffy.
Main download site is www.imagix.se, check there for updates!
Contact: gruffypuffy1234 AT hotmail DOT com
2006-06-07
- First public release. See README in each package for more details.
2SUB
This is a Teletext subtitle addon for the Dreambox 7025. It is based on the gSUB plugin for other Dreamboxes. The change in name states two things...it is NOT gSUB, as it is ported to new hardware, and the author has now joined the 2Gether Team and he wants to declare this by naming it 2SUB.
- True Type fonts, all freely selectable and scalable.
- RecDelay for recordings and Timeshift playback.
- Positioning on the screen, horizontal, vertical etc.
- Color selection.
- Render styles: Outline, Background and Outline+Background.
- Background transparency.
- GUI for settings.
- Autostarting on channel change.
- Select Primary and Secondary language.
- Hardcode/help 2SUB with the 2SUB.channels file (compare to gSUB.channels).
2LANG
This plugin is a background/autostarting plugin that selects the audio track for the current channel. It is based on what OSD language you have set, so if you have "Swedish" as OSD language, 2LANG will try and select a "Swedish" audio track if possible. Not that it is possible to override the "current OSD language" by editing a file (see inside 2LANG.audio). It will also handle the "mono-channels" like Eurosport. These channels transmit each language as a mono channel, so if nothing is done when zaping to these channels you will hear two languages... This is handled by setting up the 2LANG.audio file accordinly. See inside that for more details.
In short...this is the code that was controlled by gSUB.audio in the old plugin!
Well...best of luck to you out there and I hope that you get them to work as expected. I have had much help from my betatesters!!! THANK YOU!
Special thanks to (in random order): 2Gether (Nemesis, spacy & co. thanks for having me guys!), Gaj, Satandream and tmbinc!
Once again thanks to /Gruffy!.
