2sub/2lang 2.05: DB7025
Hi All.
2SUB/2LANG 2.05
This release has had a focus on fixing varoius issues where 2SUB has been crashing or not behaving as expected. Much improvments on the DVB Subtitles has been added and it is now working pretty good.
NOTE: There is still some issues with "lost" lines for DVB Subtitles and as far as I have tracked these down it has to do with how the PES filters are buffered in the DMM driver. I am digging into this and hopefully a solution to this will be found some day...
Special credits to my good friend WeeGull who has helped me convert the 2LANG code to use the new Enigma2 settings structure. Good work mate!
Another special credits to Gaj1, who always seem to put up with many many many releases from me...when will he get tired of testing for me??? I hope never...
All the best and I hope it is working OK for you!
/Gruffy
From the RELEASE notes:
2006-12-19 - 2.05
- Reworked how DVB Subtitles are decoded. Now works much better...but still some issues that I currently think is a driver issue...time will tell!
2006-12-19 - 2.04
- Fixed bug where text could be drawn outside the screen.
- Fixed bug with SecondaryLanguage, the GUI generated wrong stuff into the config file and this most likely ended up in 2SUB to select English as SecondaryLanguage.
- Improved DVB Subtitles, changed the MAX-STAY handling.
- Added OSD Messages feature, select in GUI to show some info in the top when 2SUB finds some subtitles. This is mostly for debugging.
- Added Framebuffer mutex lock to prevent crash in multithreading environments.
- Corrected bugs in 2LANG with newer CVS-images (thanks WeeGull).
- Now generated with newer version of BOUML...great tool! [www.bouml.org]
  • 2sub_2lang_2.05.tar.zip
    213.3 KB · Lukukerrat: 32
delfiini
Helsinki
VU+ Ultimo 4K
OpenATV
IPTV
Joku vanha Sonyn televisio
