Vu+ imagen asennusohjeet
Kirjala
Sony VPL-HW55ES + Stewart Firehawk 182cm, 3 * Nvidia Shield, Vu+ Uno4k & T90+8lnb, 28Tb Thecus N7510 NAS, Denon AVR-X1100W, AMX+ 3*Ipad, 3*KefQ1, 4*KefQ2DS, Elac S12EQ
To install a new image, you need an empty USB stick FAT32 formatted.
  1. Download image zip file for your Vu+ model;
  2. Unzip the zip file and you will have a folder named vuplus and under the folder, you will have another folder named after the model of your VuPlus set;
  3. Copy the vuplus folder (including all the sub folders and files in it) to root folder of your USB stick;
  4. If you have any folder named vuplus on any device connected to your Vu+, delete the folder or rename it;
  5. Turn off your Vu+;
  6. Insert the USB stick to the front USB port on the set;
  7. Turn on your Vu+.
Vu+ Duo
Update is done when upgrade completed message is shown on the display.
Vu+ Duo2
Push POWER button on the box (not on remote control.) when message appears on display.
Vu+ Solo
Update is done when green light blinks on the front panel.
Vu+ Solo2
Vu+ SoloSE
Update is done when the LED on front panel remains lit briefly and then starts blinking rapidly.
Vu+ Ultimo
Push - button on the box (not on remote control.) when message appears on display.
Vu+ Uno
Push CH- button on the box (not on remote control.) when message appears on display.
If, for any reason, the upgrade fails, first disconnect any USB devices connected to your Vu+ and then try again to install the new image.
If the upgrade fails again, try to use another USB stick.
Since it doesn't seems to be enough clear, we specify that to starting the Ultimo update, you have to press the button shown in the following picture.
Kopioitu suoraan vuplus-community.net sivustolta.
