PLUGIN to use ANY original card on any CVS image
Start Emu 1.5 by Redneck Eyeball
This allows you to use your original card in internal slot.
To be used for watching with original card only !
This archive does NOT contain any keys !!!
This plugin will allow ORIGINAL cards to work on ANY original and CVS image !
Changelog :
1.0 Initial release
1.1 Fixed timing problem (thnx Littlesat)
1.2 New timing fix
1.3 Internal version
1.4 Internal version
1.5 Replaced newcamd cardserver with Newcs
Support for libcrypto.so.0.9.7 in /var/lib if not available in /lib
Improved startup procedures (thnx Littlesat)
I wrote this because I do not want to be depentant on image makers to be able to use
my original card in cvs images.
Tested on DM7000-S
Tested with C+ NL card
Tested with UK FTV card
Follow the installation instructions closely !
Installation
1) ftp start_emu.cfg, start_emu.so and runemu into /var/tuxbox/plugins
2) chmod 755 runemu
3) from newcs archive, take newcs.ppc and ftp into /var/bin
4) chmod 755 newcs.ppc
5) from newcamd archive, take newcamd.conf and ftp into /var/tuxbox/config
6) from MGcamd archive, take mgcamd and ftp into /var/bin
7) chmod 755 mgcamd
8) from MGcamd archive, take mg_cfg and all .list files and ftp into /var/keys
9) insert card into Dreambox slot
10) start plugin
11) your card should now work !
Regards to xphile, Gaj1, Hemertje, Michel, Musicbob, JirkaS, klona, Sateo, floh, Hyunday Magic, alexvrs, Nil, Jcsat, PLi, Littlesat, Ronnie, Henksat, Mirakels, Pieterg, Sat-turner, Roodkapke, Rick Hunter, Ruko and Daf2000
  • Start emu as plugin v15.zip
    276 KB · Lukukerrat: 25
