Gemini Project 4.70 DM7000
chaoscreator
Kemiönsaari
The Gemini Project 4.70 DM7000
Gemini v4.7:
* Enigma of: 19.12.2008
* GCC 3.4.4 Original CVS
* Web Interface: 6.0.4-Expert
* Busybox 1.01
* Tuxtxt V1.104
* CIFS 1.44
Remotecontrol:
* 2x RED - EPG style menu
* GREEN - subservices
Addons:
* own Addon-Server via Internet, many addons with preview
* Retreiving additional functions via internet from the Gemini-Server and install them automatically
* Create your own Satellites.xml, which only contains the Satellites you really need
* Manual installation or deinstallation of addons
Camd:
* Changing the name and settings with a menu of its own
* Possibility of establishing a second socket (/tmp/cam1.socket)
Daemon / Server / Clients:
* Automatic test whether the box is connected with the internet or not (To be shown in the infobar)
* Dropbear (SSH) can be set on and off (DM500 - DM7000: Standard->off)
* Added editor to configure the cron-daemon
* Little Apache (HTTP-Server based on HTTPD)
* Upnp Client and Server (for DM500/56x0 must be installed from Gemini-Server as addon)
* Settings for syslogd
* Automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted. Perfect for DVD- or Net-Drives (Editor can be found in the BP)
* NFS-Server (based on the NFS-Kernel-Modules, not for DM500, DM500+ and DM56xx)
* Provider, Frequencies, Symbolrate and FEC can be displayed in the Infobar (If the Skins supports this function)
* Display of EMM, ECM or "Expertinfos" are adjustable
* Moved Gemini events (Ripper, Calendar, email-Checker) from BluePanel Menu into the infobar (eLabel-Name = geminievent)
Files / Devices
* Support for CD-ROM/DVD-drives ,regardless of using IDE or USB
* Random function for all kind of soundfiles
* Backup function
* Two new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
* Support of the bigger remote on 500 and 500+ (normaly shipped with 70XX/600pvr - activate on BP->Extras/Settings)
* Support for FLAC, OGG/Vorbis and WAV (please install codecs in the BP)
* Functions for SWAP (virtual memory). Create, delete, size and location.
* Device-Manager for HDD / DVD / CF / USB
* Drivers for USB-Cardreaders are now included in the Image but are not loaded automatically.
EPG
* additional functions (e.g. dishnetwork, cache, location)
* search all channels for an event or an own string. Timers can be added immediatly (Press "Menu" in the epg or use use BP -> extras -> EPG-Refresh)
* Infos of the recorded movies can be shown without starting the movie
* refresh EPG using the enigma-timer (BP -> extras - EPG-Refresh)
* autosave for EPG-cache ( BP -> Extras/Settings -> EPG-Settings)
* Duration of current event in the programm overview ( Menu -> Info -> EPG)
* general information about the EPG Data (BP -> Info-> EPG-Settings)
* a time period for the EPG Data can now be defined (BP -> Extras/Settings -> EPG-Settings)
Extras:
* Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3´s) (for DM500/56x0 must be installed from Gemini-Server)
* RSS und Weather Plugin (for DM500/56x0/7000 must be installed from Gemini-Server)
* System Info: Many extra box infos like HDD temprature, stream-rates (>=7000) or kernel-, memory- and prozessinfos.
* change the settings for recording (before Time, after-recording time,, location and recover-function)
* Create your own satellites.xml including only the satellites you really need.
* Calendar for iCalendar format + reminder ( Supported by MAC, KDE, Thunderbird, Goole calander, Rainlendar...). Standard folder is /var/etc/ical (for DM500/56x0 must be installed from Gemini-Server)
* eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD (for DM500/56x0/7000 must be installed from Gemini-Server)
* disable the TV - output while taking a recording, streaming a movie and manually (usefull for boxes with very low lan-speed)
* update system time via transponder or internet ( Protocol RFC868 )
* eMail-Checker extended with SSL support (Overview of your POP3 or IMAP accounts)
* create password using the BP (BP -> Extras -> Pwassword)
* rotate al kind of pictures. Also automatic rotation using EXIF (must be activeted using the menu)
* Re-Zapp, zapps after X-minutes to the actual Channel (BP -> Re-Zapp)
* Displays, wether the box is an original one or not (using MAC adress, BP -> System -> Dreambox -> Manufacturer)
* the Jukebox, Please install as addon.
Recordings:
* records into different folders ( the settings have to be done in the Timer-Menu)
* LED´s are flashing during record (Boxes without display). Must be set in BP -> Extra -> Record
* import of recorded movies every time you enter the Video-Menu or only once when the Box ist starting (BP -> Extras -> Record)
* Records can now be done in the new Eniga2 format (*meta files) or as usal as "recordings.epl" (BP -> Extras -> Record)
* USB-Cardreaders can be activeted over the menu (BP->Extra->USB-CardReader
* With the variables "show_gemini_server" and "show_camd_plugins" the addondownload and the server can be influenced (/var/etc/Gemini.conf)
Fix + update:
* After- and Prerun at records increased to 20 minutes
* after a backup-restore the datas are available immediately, eg. bouquets
* Crash at web-access to PMT-Pid without a valid PAT
* Flickering of the popup "Channel change: Service not found"
* Prevent the popup "Channel change: Service not found" while the rotor is moving
* have a look at the CVS
Interfaces WebIF:
http://127.0.0.1/cgi-bin/setKey?typ=STR&.test&val=blabla
http://127.0.0.1/cgi-bin/getKey?typ=INT&.itedvb/int-test
We'd like to thank everybody who participated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized by us, but must be developed by the CVS-Team
This images doesn't contain any keys or softcams. Backups or other modified Images are not released by and won't be supported in any way...
Gemini Images may only be used on receivers of the manufacturer Dream-Multimedia-TV.
The use of this Image is on your own risk.
Recommendation:
if several processes running in background. We take no responsibility for direct or indirect damages.
Löytyy monelta saitilta
esim.
http://www.gccadm.net/forum/viewtopic.php?t=46893&start=70
