kustijean
- vu+ duo 2
Black Hole 2.1.5
Warning: This image MUST BE INSTALLED IN FLASH.
Warning: Don't mix images with OpenGL animations and images without animations in multiboot because they use different drivers. If you have an OpenGL image in flash you can only use OpenGL images in Meoboot.
Warning: Previous personal backups are not compatible with this image. Please use software manager to backup your settings before you flash.
Known Issues: Xbmc External Player not working yet.
Note for Meoboot and OpenGL images:
Because OpenGL images have a different boot procedure and the framebuffer is loaded at the end of rcS it is not possible to have the Bootmenu.
For this reason to change image you have to go into Meoboot plugin, select the image you want to boot and click on "Boot Image" button.
WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot. The image MUST be installed in flash.
Black Hole does not support images not installed in flash.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Button Red short press= access HbbTv functions
Button Red long press= Red Panel (Parallel Universes Teleportation)
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Online Black Hole image update
Manual Install BH packges (Manual installation of Black Hole packages)
Red Panel
BH Parallel Universe Teleportation
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to Pedro_Newbie for Backup script
Thanks to Littlesat and Pli Team for the original autolanguage and subtitle options code
DISCLAIMER
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PUBLISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE (TERM OF USE)
THE BLACK HOLE IMAGE IS ISSUED FOR THE FREE USE FOR ALL USERS PROVIDED THAT IT WILL NOT BE CHANGED IN ANY WAY AND THAT IT WILL ONLY BE USED FOR LAWFUL PURPOSES.
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REVOKE OF THIS LICENSE.
This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.
Announcements - Black Hole 2.1.5 | VuPlus Community
- New: HQ 5 Full Hd Skin 1920x1080 (duo2, solo2, soloSe, uno, ultimo, zero)
- New: OpenGL animations and Xbmc (duo2, solo2, soloSe)
- All drivers updated
- fix autoresolution plugin
- [hbbtv] fix crash parsing xml
- [hbbtv] fix VOD play problem
- fix keymap bug
- fix channel skip
- change default resolution to 1920x1080 (only models with full hd skin)
- update languages hr, it, no
- meoboot: add support for OpenGL and Xbmc images
- update Usbtuner
- WIFI: update driver RTL8188EU
- WIFI: update driver RTL8812AU
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
