7025: Gemini2 v3.0
crashi
7025: Gemini2 v3.0
Gemini2 v3.0:
* Engima from: 09.08.2007
* GCC 4.1.1 Original CVS
* Kernel 2.6.12.6
* Busybox 1.0.1
* Tuxtxt 1.95
* CIFS 1.44
* long BLUE -> PiP
* RED - Record
* GREEN - Subservices
* Yellow - Timeshift
Addons:
* Downloading and installation of additional features via internet from Gemini server.
Camd:
Daemon / Server / Clients:
* Upnp Server / Client
Infobar / OSD:
* Showing Onlinestatus when the Box is connected to the Internet (must be activated in the BP -> Extras/Settings/Online)
Files / Devices:
* Support for CDROM/DVD no matter ift it is IDE ur USB
Extra:
* Password can be changed over the menu.
* Spinner (response time now adjustable, 0 is off).
* ECM-Expert now using a seperate window
* Changed the addon routines. There will be a perview available by many addons and skins (due to the new structure of the addons we also did the version jump)
Fix + Updates:
* see CVS
and won't be supported.
Download via Database
http://www.dreamboxworld.org/dbw/dm7025/gemini2-300-dm7025-200708091858.zip
